May 29, 20206 yr I'm having an issue with several web sites where the email address is being entered in the username field for the site even though there is a separate username stored in Enpass. I have to move the email address associated with the Enpass entry to the notes field to prevent it from filling in the user name field at the site. I'm using Enpass version 6.4.4.353 on my Pixel 2 running Android 10. This functions differently on my Windows 10 desktop which fills the proper username on the same site. Edited May 29, 20206 yr by Ingrove
June 1, 20206 yr Hey @Ingrove Sorry for the trouble you are going through. We would like to share that Enpass uses the first ‘field type’ that is either username or email to auto-fill the username/email field. For eg; if the field type of username is numeric or any other apart from email and username. Then Enpass will not fill it. Please change the username field type to the username only and then try to auto-fill the details. Also, you can refer to this link. Thanks.
June 2, 20206 yr Author Thank you for your response. Unfortunately, it doesn't really solve the problem. Enpass is auto-filling the user name field on some web sites with the email address information instead of the information stored for the user name. In Enpass, the Username field is set to (type = username) and the E-mail field is set to (type = email). If I set the E-mail field (type = text), Enpass functions correctly. This only happens in the Android version on Enpass. The desktop version fills in the correct information without having to change the E-mail field type to text. Unless there is an explanation I will continue to define the E-mail address field as (type = text). Thank you.
June 3, 20206 yr Hey @Ingrove Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
June 9, 20206 yr Hi @Ingrove, We need a little input from you, so please let us know the following details so we can help you better: Are you facing this problem on all websites and apps? It possible, please share the name of the website/App. Which browser are you using as a default browser and its version? Are you facing this problem when you try to Autofill via Autofill using Accessibility or Android autofill service? Thanks for your co-operation.
July 14, 20206 yr Same thing here. Always uses email field to fill in username instead of username field. Makes using enpass useless for auto fill.
July 15, 20206 yr Hey @STiK Sorry for the trouble. If you've not already done so, rearrange the username field line above the email and then try to auto-fill on the particular website/app and share your findings. To do so, you may refer to this link. Thanks.
July 15, 20206 yr Sorry, as you all have been told before, this does not seem to work. If I put my email in the username field and my username in the password field it works. Band-Aid not a solution.
July 15, 20206 yr Hey @STiK Sorry for the trouble you are having. I have shared your inputs to the team. Hopefully, an update for Enpass will be released soon in which we've significantly improved auto-fill feature. Please stay tuned for the new update and let us know if the problem still persists after the updated version. Thanks.
August 12, 20206 yr Hey All, We've released an updated version of Enpass(v6.5.0) for Android device in which we have fixed some issue related to auto-fill. Could you please update the app to the latest version and let us know if you're still encountering the same issue with the app? Thanks for the co-operation.
September 5, 20206 yr Hello, I have the same problem. Even if I change the fields and username is at first place enpass(v6.5.0.390 - android) is still using the email adress for autofill. KR Klaus
September 7, 20206 yr Hey @Enpass_User Welcome to the forum! We need a little input from you, so please let us know the following details so we can help you better: On which device and OS version are you having this issue? Are you facing this problem on all websites and apps? It possible, please share the name of the website/App. Which browser are you using as a default browser and its version? Are you facing this problem when you try to Auto-fill via Auto-fill using Accessibility or Android auto-fill service? Thanks for your co-operation.
September 8, 20206 yr Same issue for me. Using Enpass 6.5.0.390 and Android 10. I don't have an exhaustive list of when it happens, but I've primarily experienced it when I'm using the Android Autofill in an installed App. Examples from this morning were the TD Ameritrade app, Fidelity app, and American express app (was working on finances). I've resorted to moving my email address to the notes field, as was mentioned by another user, for a work around.
September 9, 20206 yr Hey @Sean Miller Welcome to the forum! We've released an updated version of Enpass(v6.5.1) for Android device. Could you please update the app to the latest version and let us know if you're still encountering the same issue with the app? Thanks.
