May 31, 20206 yr PIN REQUEST 3 TIMES INCORRECT Blocking and notification on my smartphone then a security code will be sent on email and you have to enter the master password and 6-digit security code to verify yourself is that possible
June 1, 20206 yr Hey @enpass pin Thanks for using Enpass and writing to us. Please refer to this FAQ. To add extra randomness to your Master Password, you can use a KeyFile in Enpass. A KeyFile gets appended to your Master Password before the actual encryption or decryption of your data happens. So, even if someone, somehow gets access to your data and your Master password is also compromised (a worst-case scenario), your data is still safe as the Key-file (stored on your device) is required to decrypt your data. For more details, please refer to this link to our user manual page. Thanks.
June 4, 20206 yr On 6/1/2020 at 1:51 PM, Garima Singh said: Hey @enpass pin Thanks for using Enpass and writing to us. Please refer to this FAQ. To add extra randomness to your Master Password, you can use a KeyFile in Enpass. A KeyFile gets appended to your Master Password before the actual encryption or decryption of your data happens. So, even if someone, somehow gets access to your data and your Master password is also compromised (a worst-case scenario), your data is still safe as the Key-file (stored on your device) is required to decrypt your data. For more details, please refer to this link to our user manual page. Thanks. OP made a feature request; He wants Enpass to lock the database after 3 attempts, and then send an email to it's registered owner with a OTP to unlock it again. Edited June 4, 20206 yr by Ivarson spell
June 4, 20206 yr Hey @Ivarson Thanks for writing back. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for the suggestion!
