June 8, 20206 yr Hello fellow users, Is there an option in Enpass to enable password verification by re-typing the password twice when you create a new entry? (to make sure you made no typos when entering the password) Thank you!
June 9, 20206 yr Hi @chamomile, Welcome to the forums! No, unfortunately there's no option to verify password fields. But, we're taking this forward as a feature request. Thanks.
June 9, 20206 yr Author Hi Pratyush! Thank you for taking a notice of this matter. I tried entering several entries manually and then realized that one can easily make a typo without even knowing about it, because there is no password confirmation text field (unlike Keepass and many other password managers). Please kindly implement this. Thank you! PS: Also, why it is not possible to post on your forum when using a VPN??? I need it for security reasons, but the forum engine complains about it and requests me to disable it :(( Edited June 9, 20206 yr by chamomile
June 10, 20206 yr Hi @chamomile, Thanks for writing back in. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback! Regarding VPN, our anti-spam filters out any activity from the VPN. Hence it is not possible to post using a VPN.
