June 11, 20206 yr I have an up=to=date Debian (10) installation and iCloud sync stopped working. On reconnecting not even the browser get started. I tried another browser as default, same result. Since I could not get Sync to work I totally removed Enpass and installled the latest version today. When I choose iCloud sync I get a message: Error during recovering data (translated from Dutch) even before something else happens. Any idea what could cause this problem? Debian is my main install and without Enpass....
June 12, 20206 yr Hi @Krit, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us. Are you able to access all your data on any other devices.
June 12, 20206 yr Author Mmmm... - Windows 10, PC - IOS (iPad Pro 12.9 , iPhone SE) - Debian, Manjaro, CentOS in Virtualbox on PC - Debian on laptop AsusPro i7 8Gb - ElementaryOS, Manjaro, MX Linux, OpenSuse, Zorin, CentOS, Solus, Ubuntu, Mint in Boxes on ASUSPro I always have the last stable version of Enpass running. I can access all my data on all other devices/os After resedttingh Enpass, uninstalling it en installing it again after a reboot I dont get an error code on sync, I just get a message that Enpass will open the iCloud page but nothing happens as soon as I try to setup a sync with iCloud.
June 15, 20206 yr Author Additional info: Just installed Enpass in a VirtualBox containing a Debian 10.4 install that does not had an Enpass install before. The same result here, instantly after clicking iCloud this message occurs. No spinning wheel or other messages, no browser opened. (translation: Error during recovering data) Edited June 15, 20206 yr by Krit
June 15, 20206 yr Hey @Krit Thanks for sharing the details. Could you please change the default browser and try to setup sync again with iCloud. If the problem persists, please share the video of the same while setting up the sync. Thanks for the co-operation.
June 15, 20206 yr Author Ok, I have tried this again with both Gnome Web and Midori. Changed the default browser, started Enpass and clicked iCloud. With the same result:
June 15, 20206 yr Author Additional info: Just did a new install of Debian 10.4 this time with US English user interface. Then installed Enpass, same result. So no other packages installed by me, nor the user interface language can be the problem.
June 16, 20206 yr Hey @Krit Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it. Will get back to you once we receive any update. Thanks for your cooperation.
June 17, 20206 yr Hi @Krit Thanks for the patience. We would like to share that the issue has been reproduced by the QA team. Now our Dev team is looking into this issue to resolve and hopefully, a fix will be available in the future update. Thanks for your co-operation.
July 10, 20206 yr Hello i experienced the same problem with debian buster 10.4 Is the issue still under investigation?
July 13, 20206 yr Hey @ENPP Thanks for writing to us and welcome to the forum! I would like to share that our team is looking into this issue. Your co-operation will be highly appreciated. Thanks for understanding.
July 14, 20206 yr Hello there, just like to "confirm" that I experience the same isssue on Kali Linux. Error message when trying to sync with iCloud is "Error while restoring data." xxx@yyy:~$ uname -a Linux kali 5.5.0-kali2-amd64 #1 SMP Debian 5.5.17-1kali1 (2020-04-21) x86_64 GNU/Linux Thx for investigating!
July 14, 20206 yr Hey @AgentBrownie Welcome to the forum! We would like to share that our Dev team is looking into this issue to resolve and hopefully, a fix will be available in the future update. Thanks for your co-operation.
