June 16, 20206 yr I've 10 days left on my premium Dashlane licence. I'm starting the evaluation of Enpass and might switch usong the actual premium price promotion https://www.enpass.io/pricing/ I've installed Enpass on my iPhone and Mac Book Pro. The migration of some 250 registration from my Dashmane ti enpass went allright in a few seconds. The sync is working with vault installed on Dropbox. Since my trust in the Cloud storage is limited, I prefer to have my vault stored on my own Synology NAS storage organization. I've not seen this possiility in the sync option. Is it possible ? My second question : is it possible to open a website double cliking on an Enpass registration url? It does not work when I do it. Many thanks in advance for your help and experience sharing. Kind regards.
June 17, 20206 yr Hey @Castio Welcome to the forum! 10 hours ago, Castio said: Since my trust in the Cloud storage is limited, I prefer to have my vault stored on my own Synology NAS storage organization. I've not seen this possiility in the sync option. Is it possible ? Yes, you can sync with own synlogy using WebDAV. You can sync your Enpass data with Nextcloud, OwnCloud, pCloud, and etc using WebDAV. To do so, please refer to this FAQ. Also, please look at this link for more details. 10 hours ago, Castio said: My second question : is it possible to open a website double cliking on an Enpass registration url? It does not work when I do it. Yes, it is completely possible to open any website in your default browser saved in Enpass by single clicking on the URL. Please revert if you are getting any error while doing so. Thanks.
June 26, 20206 yr Yep WebDAV with Synology is working great overhere! I added the vault in a Synology Drive map (version history) so I can restore the vault when needed (never needed it). I'm using Cloud sync to create an extra backup on my dropbox. In the past I had some problems with connecting to WebDAV through enpass. I think it depends on the device but most of the time you need to link it to the enpass folder ( https://www.domain.com:port/home/Drive/Enpass ) or just the folder before that ( https://www.domain.com:port/home/Drive/ ) Edited July 5, 20206 yr by TREMOR
June 29, 20206 yr Hey @TREMOR Thanks for sharing it. Please revert us back if you face any issue or if you have any concerns with Enpass. We will be glad to assist you. Thanks.
