June 17, 20206 yr Hello, I am trying to sync to my OneDrive account which has been working well previously. It's all of a sudden stopped working and I am now receiving the following error: Something went wrong while syncing with cloud. Error code: 1208400 Here is what I have done to try and fix it: Ensured my iOS app is on the latest version of the app. Enpass version 6.4.5. Disconnected the OneDrive cloud and reconnected again. Restarted my iPhone. I am running on iOS 13.5.1. Can someone please help? Thanks Scott
June 17, 20206 yr Hey @ScottieT125 Welcome to the forum! For quick troubleshooting, please follow the help article here. If that doesn’t help, please share the following details so that we can investigate where the problem could be. On which all devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Thanks!
June 18, 20206 yr Author Hi Garima, Thanks for this, I had already done these things. Please refer to my original message re answers to your questions. Re the date and time setting, yes this is set to automatic on all devices. Sync is working fine on my Mac and my iPad. It just doesn't sync on my iPhone. Refer above for the error message. Thanks Scott
June 18, 20206 yr Hi @ScottieT125 Sorry for the inconvenience caused to you. Please follow the below steps to restore the sync: Take a manual backup of the data on all the devices. Disconnect the sync on all devices. Open One-drive account on any browser and Remove the Enpass folders from One-drive account. Login to the site https://account.live.com/consent/Manage with the same Microsoft account and delete all the permissions for Enpass. Re-set up the sync with One-drive on all the devices and check. If the issue persists, please let us know.
June 19, 20206 yr Author SOLUTION: For anybody else who is experiencing the same, I deleted the app from my phone and reinstalled it. That seemed to fix the issue for me.
June 19, 20206 yr Hey @ScottieT125 Thanks for notifying us. I am glad to know that you have managed to resolve the issue.
July 6, 20206 yr Hello, I have a problem sync my Iphone with my one drive account. I´ve tried all the options yet still I cannot sync. I cannot find the sync_default.walletx file. Could that be the problem. Wait your reply. Thanks. Edited July 6, 20206 yr by reautogye@gmail.com miss an information
July 6, 20206 yr Hi @reautogye@gmail.com, Apologies for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us. Thanks for your co-operation.
July 7, 20206 yr 18 hours ago, Pratyush Sharma said: Hi @reautogye@gmail.com, Apologies for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us. Thanks for your co-operation. Thank you. I deleted enpass from one drive, reinstalled enpass on my Iphone and fix the problem.
July 7, 20206 yr Hi @reautogye@gmail.com, Thanks for notifying us. I'm glad to know that the problem has been resolved.
