June 18, 20206 yr Hello everyone! I'm writing to get recommendations about how and if it's the best approach for merging two vaults without having duplicate entries. Probably some of you know that Enpass locks the some of it's files then Onedrive can't backup those without closing Enpass, so I don't know why Onedrive downloaded from cloud storage one old vault files and then I noticed some credenciais missing. My solution was to create another vault (without cloud sync) using one of the local backups then I recoverd the credentials I had, but now I have two "repeated" vaults. One more complete and other less complete. The problem is: the oldest with less credentials is the one that I sync do Google Drive, besides of file sync with Onedrive. What do you guys recomend to merge or solve that? Best, Ellery
June 19, 20206 yr Hey @Eduardo Ellery Sorry for the trouble. I was able to find a support ticket you created and reverted on the same. To prevent duplication of efforts, please revert on the same if you have any concerns. Thanks.
