June 19, 20206 yr Hello, I'm pretty new to Enpass, coming from Keepass. Now I searched for an History function and found out that Enpass should have such an functionality as well. In the release notes from the forum I have read that this should show up after you change any field (except the notice field). But I cant see this anywhere. Is this a bug or wasthe feature removed? I use the Win32 app for Windows and have a Enpass Pro licence. Greetings, Nico
June 22, 20206 yr Hi @Romanicus, Welcome to the forums! Once you’ve updated any field, its changes get recorded as Field History in Enpass. To see the field history, right-click on the field’s value from the details screen → Click on the History. If you are still facing this issue, please let us know the following information: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks!
June 23, 20206 yr On 6/22/2020 at 11:02 AM, Pratyush Sharma said: Hi @Romanicus, Welcome to the forums! Once you’ve updated any field, its changes get recorded as Field History in Enpass. To see the field history, right-click on the field’s value from the details screen → Click on the History. If you are still facing this issue, please let us know the following information: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks! Does the password history also show the previous password or just provide details of when it was modified?
June 24, 20206 yr Hi @Diarmuid O Donovan, Thanks for writing back in. The field's history in Enpass only has changes which are made in Enpass only.
July 17, 20206 yr Author On 6/22/2020 at 12:02 PM, Pratyush Sharma said: Hi @Romanicus, Welcome to the forums! Once you’ve updated any field, its changes get recorded as Field History in Enpass. To see the field history, right-click on the field’s value from the details screen → Click on the History. If you are still facing this issue, please let us know the following information: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks! Thanks, this is exactly what I was looking for and it works for me now. Maybe I have the right-click action overlooked in the manual, but if not, can someone of the Enpass Team add this to it please? Thanks again and have a nice weekend. Greetings Nico
July 17, 20206 yr Hey @Romanicus Thanks for writing back. I am glad to know that the problem has been resolved. Please let us know if you have any concerns with Enpass. Thanks.
