June 20, 20206 yr First off, just wanted to say I'm a long time user of Enpass - awesome product I love it! But recently I've started to make use of more vaults, and I've hit the restriction of only 1 vault per OneDrive account. I have three vaults setup: 1 person, 1 shared with my wife, and 1 for work stuff. My personal vault is stored on my personal OneDrive account. My account shared with my wife we had to store on Google Drive. My work stuff is stored on my work OneDrive account. Trying to setup a personal and business OneDrive account in Enpass is NOT easy. It opens the browser window, which in my case defaults to auto sign in for my personal account. So I had to open a guest browser window, sign into my work account, and get Enpass to open a tab in that browser window to successfully sign in. And I've run into a few little bugs that make me worry that this setup might not be stable long term. For instance, my main account suddenly stopped syncing after a while, then it would no longer accept my master password. So then I backed up my data, had to delete everything on my personal onedrive and resync. Never had this occur until I added the OneDrive for Business account. An easier setup for this scenario would be greatly appreciated. Would it be possible to allow more than a single vault per OneDrive account? Or is this a OneDrive restriction? It feels like you could just create multiple vault folders - Enpass01, Enpass02, Enpass03, etc. But maybe OneDrive sees all Enpass connections as coming from the same app and therefore only allows it access to one folder? In that case, could Enpass just use sub folders of that primary folder? For instance top folder is Enpass, then sub folders are vault01, vault02, vault03, etc. I would love to see these features implemented. Thanks a bunch!
June 23, 20206 yr Hi @skinneejoe, Thanks for using Enpass and writing to us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
