June 20, 20206 yr There are two ways to code Face ID on Android. One that requires you to press the confirm button after the face recognition process and one that doesn't. The extra confirm button press doesn't add any additional security. I wish Enpass would switch to the one that just unlocked when it saw your face. I have uploaded an example of the Experian app that used the one that doesn't require a confirm button press.
June 22, 20206 yr Hi @EImmerman, Sorry for the inconvenience caused to you. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
August 8, 20206 yr Author Everyday I find a reason to confirm my choice of using Enpass over the other password managers!! Thank you for listening. I see my feature request made it in the latest version. Keep up the amazing work!!!!!
August 10, 20206 yr Hey @EImmerman Thank you so much for your kind words and glad to know that you are enjoying Enpass. We really appreciate you taking the time out to share your experience with us. Thank you once again.
