September 12, 20179 yr Lastpass import, data missing Hello, is it normal that some passwords are just gone when importing from Lastpass. Exporting from Lastpass to .csv creates 599 entries, importing to Enpass and then export to .csv = 411 entries. And some real passwords are just gone. Which is troublesome...
September 12, 20179 yr Hi @roccolord That's really strange! It will be a great help if you can share some more info like OS version, Enpass version, LastPass version and default language of LastPass so that we can take a closer look into it. Thanks for your co-operation!
September 12, 20179 yr Author Hello, I used the latest Lastpass chrome extension for OSX for export. I used latest Enpass OSX app to import. Lastpass language is English.
September 12, 20179 yr Author I can't post my input that doesn't import correctly here since the forum thinks it's spam and stops me from posting it... Bummer. And it's not possible to attach files... Will a attach a picture of my post....
September 15, 20179 yr Hey @roccolord Thanks for sharing the details. I have forwarded this issue to the dev team for further improvements. Your patience will be highly appreciated!
