[SOLVED] How to use multiple vaults on iPad
It must be very simple, but I can't see it... on my MacBook Pro I can use multiple vaults that are securely synced into my Google Drive. I want to do the same thing on my iPad, but I can only sync one vault.
How do I add the second one? Thank you!
Hey @Molerat
Welcome to the forum!
To create or add vaults in Enpass, please go through this step- Open Enpass > Click on 'Settings' > Tap on 'Create a vault'. Also, you can refer to this link of our user manual. Also, I would like to share that multi-vault feature of Enpass in any mobile platform requires Enpass premium license. To know more, refer to this link.
Thanks.
Thank you Garima - it worked. I find it a bit weird that it would be called "Create a vault" because it sounds like you are about to create a new vault, when actually you are just importing an existing one.
  • semi_mod changed the title to [SOLVED] How to use multiple vaults on iPad
  • semi_mod locked this topic
