September 17, 20179 yr Can you make some changes so that the app would show the key press (Copy password / Copy login) in app's status bar with counter how many seconds left to remove information from clipboard. Thanks Much
September 18, 20179 yr Hey @thebob6 Thanks for stopping by and suggesting this feature, it'd be a useful addition to Enpass. I've noted it down for internal discussions. Cheers!
December 29, 20178 yr I would love to see a detailed enriched notification option as when I open an app and enpass has an entry saved for that app, give an enriched notification (maybe hidden in notification tray) showing login id/ username and option to copy password and TOTP
