August 1, 20206 yr Hi, I just purchased Enpass and I would like to import, but when I go to File>Import is grayed out. Help.
August 4, 20206 yr Hi @DannyK, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Let us know from which software you have exported data? If possible, share the screenshot of the issue? Thanks for your co-operation.
