August 5, 20206 yr Enpass won't fill in login credentials for https://www.barnesandnoble.com. Seems to have a problem with a login frame. I can open the login frame in a new tab, and Enpass will populate the login credentials. Enpass Firefox extension 6.4.0.
August 6, 20206 yr Hi, Sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Which Firefox version are you using? Are you facing the same problem with other browsers too? Thanks for your co-operation.
August 6, 20206 yr Author Quote On which device (along with OS version) are you using Enpass? Windows 10. Quote Which Enpass and Enpass extension version are you using? Enpass 6.4.2 (669) Enpass Firefox extension 6.4.0. Quote Which Firefox version are you using? 78.0.2 (64-bit) Quote Are you facing the same problem with other browsers too? Not tried.
August 7, 20206 yr Hi @jakejohn, Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it.
