August 7, 20206 yr I would like to be able to create sections in a randomly generated password (pronouncable or not pronouncable) in order to randomize those sections again. example: randomly generated password (pronouncable= yes, length 109= 15 words, uppercase= yes, lowercase= yes, separated by= underscore): Named5_Varied_9Refold_1george_Croix_6foggy_7Undying_Dents_Meyers_frock3_Exquisite_Hums_1Anaconda_dud_Uncouth6 This would be divided into either sections with random length or user-preference based length sections like so in case of unpronouncable: Named5_Varied_9//Refold_1george_Croix//_6foggy_7Undying_D//ents_Meyers_frock3_//Exquisite_Hums_1Anac//onda_dud_Uncouth6 This would be divided into either sections with random length or user-preference based length sections like so in case of pronouncable: Named5_Varied//_9Refold_1george_//Croix_6foggy_7//Undying_Dents_Meyers//_frock3_Exquisite_//Hums_1Anaconda_//dud_Uncouth6 Each individual divided section can then completely separate from each other be randomized based on a user-preference amount of times thus creating a truly randomized password for extra security. A bit like the concept of encrypting with different cryptokeys.
August 7, 20206 yr Hi @Woutcam, Thanks for writing in. I have noted down your inputs and forwarded it to the concerned team for further consideration.
July 15, 20215 yr Author So, any feedback on this? Coming up to a year. Don't mind if it's rejected but feedback should always be given...
July 16, 20215 yr @Woutcam, Thanks for reaching out to us. I have checked the corresponding ticket on our internal system. I regret to inform you that we are not considering it at this moment.
