August 11, 20206 yr So after opening the App on my iPhone X it stated that I reset my face I.D which I didn't but I use back ups to ICLOUD but I can't remember the Master Password can I some how add it or open it from a Sync File or find it in a iPhone back up ? The Password I originally set up my App hasn't changed in years as I relied on the Face ID Any help greatly appieated
August 11, 20206 yr Hey @Darren Welcome to the forum! Do you have access to Enpass using the Touch-ID? If you've forgot the master password, there's no way to recover it as Enpass doesn't store or save the password anywhere. Thanks.
August 11, 20206 yr Author But I have sync_default.walletx file on my iCloud can I restore it ? according to your site page it can be done ! https://www.enpass.io/master-password-not-working/
August 12, 20206 yr Hey @Darren Thanks for writing back. What's the Enpass version you're using? The file extension is for an older version of Enpass i.e. version 5. Thanks.
