September 25, 20179 yr Doubleclick to open attachments would be ice. Now you have to click first on anattachment and then select "open" from the list. Doubleclicking is normally used to open an item.
September 26, 20179 yr Hi @JohnnyX Thanks for your suggestion. I have noted it down and will definitely consider it. Cheers!
