August 21, 20206 yr Unfortunately, I can't restore from Dropbox. I'm on Ubuntu 20.04 with current Enpass installed. It just says "Error while restoring data."
August 24, 20206 yr Hey @bot47 Apologies for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which all devices and OS versions (mention all) are you using Enpass? Are you able to access all Enpass data on any other device? Which Enpass version are you using on each device? Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Thanks.
August 27, 20206 yr Hi @Garima Singh, Thank you for your response. Fortunately, the latest update fixed the issue.
