August 22, 20206 yr This site ( https://mma.sinopac.com/MemberPortal/Member/NextWebLogin.aspx ) does not fill the fields correctly when using the autofill function, the webform is saved and the corresponding fields are set. The autofill only fill the two fields.
August 24, 20206 yr Hey @bestpika Thanks for sharing the details. I have noted down this issue and forwarded all the inputs to the QA team to look into it. Will get back to you if we need any other info. Thanks for the co-operation.
