September 29, 20179 yr hello enpass forum, I decided to change from mSecure to enpass and since today I use the pc-, ios- and android version of enpass on my pc and mobile devices. how can I migrate my 200 data sets from mSecure in best quality to enpass? best regards, Ludwigjjj
September 29, 20179 yr Hi @Ludwigjjj I will definitely help you in migrating your data from mSecure. First of all, I would like to share that importing data from other password managers is currently possible only from our traditional desktop versions. They are available for Windows, Mac and Linux and can be downloaded from our website. So once you have imported data, you can easily migrate that to your other devices using Sync or Backup/Restore feature of Enpass. To import mSecure data into Enpass please follow these steps: Open mSecure app --> Go to File --> Export -->Save this file as "filename.CSV". Now import the same file into Enpass by using Generic CSV/DSV Format. For more details please check out our user manual. Cheers and welcome to Enpass!
September 29, 20179 yr Author 3 hours ago, Anshu kumar said: Hi @Ludwigjjj I will definitely help you in migrating your data from mSecure. First of all, I would like to share that importing data from other password managers is currently possible only from our traditional desktop versions. They are available for Windows, Mac and Linux and can be downloaded from our website. So once you have imported data, you can easily migrate that to your other devices using Sync or Backup/Restore feature of Enpass. To import mSecure data into Enpass please follow these steps: Open mSecure app --> Go to File --> Export -->Save this file as "filename.CSV". Now import the same file into Enpass by using Generic CSV/DSV Format. For more details please check out our user manual. Cheers and welcome to Enpass!
September 29, 20179 yr Author Hi Anshu, thanks a lot. I will migrate my data this evening. will there be a lot of manuell additional work for me? best regards, Ludwigjjj
September 30, 20179 yr Author The result of the data import is a disaster. Of my 300 records in mSecure, only 23 was detected and imported, and these 23 were also absolutely faulty; many special characters and incomplete. What can I do? Edited September 30, 20179 yr by Ludwigjjj
September 30, 20179 yr Author Some more informations: First I tried to import as mSecure files, the result you can see in my last post. After that, I tried to import as Generic CSV/DSV Format. All formats (,-:-;-/-TAB - Komma, Doppelpunkt, Semikolon, Schrägstrich und Tab) "told" me: 600 data sets.
