August 28, 20206 yr Enpass Desktop on Windows 10 has stopped syncing with OneDrive. Error message: Synchronization Error. Password for data on Onedrive necessary. I tried to re-enter the password --> no success, getting message pw is wrong logged out on onedrive via browser directly and logged in again with the password tried above --> success, so the pw is definitely right
September 3, 20206 yr Having same problem. I have tried disconnecting from OneDrive and then reconnecting, this doesn't work either
September 4, 20206 yr Hi @Rick Garner, Welcome to the forums! Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us.
October 22, 20206 yr Hi, I meet the same issue, not possible to sync with onedrive on several devices : - Windows 10 app (hp zbook i7-9850H / 32Go / x64) / Enpass 6.5.2 (724) - Android WAS-TL10 8.0.0.371 (C636) (Huawei P10 lite) / Enpass 6.5.2.404 Other windows 10 computer... There is no code, it only says (translation French to English) : "sync error - Data password for Onedrive is required", and when I enter my microsoft account password it never works. The same with Enpass password. Thanks for support. Regards
October 23, 20206 yr Hey @Jym25 Welcome to the forum! We regret the inconvenience. Please follow the below steps to restore the sync: Take a manual backup of the Enpass data on all the devices. Disconnect the sync on all devices that are synced with Onedrive. Remove the folders Enpass and Enpass1 on One-drive account. Re-set up the sync with One-drive on all the devices and check. If the issue persists, please let us know. Thanks!
October 31, 20206 yr Hey @Garima Singh, Thank you for your support. The sync is back, your method was efficient. Thanks.
November 9, 20205 yr I have been encountering a similar problem. Thanks for your tips @Garima Singh, they helped me solve the problem. Edited November 9, 20205 yr by benpal
