October 9, 20179 yr Reproduction steps: Start windows Open my daily software (PhpStorm, DataGrip, Postman, several others) Open enpass for the first time Enter password Output: Enpass shows the loading display. This keeps on for some time after which the lock screen is displayed again. I haven't measured but it seems to take as long as my lock duration is. If I click inside the enpass window while it's trying to log in unsuccessfully, Windows shows a "window not responding" error for the enpass window. Expected output: Enpass is logged in. Some more information: This happens for me usually daily. It might happen twice or more, but I can't say for sure. Usually this is in the first hour after startup. For the rest of the sessions (maybe 3-8 more) , login works as expected. Even more information: What is your system configuration: Windows 7 Pro, 64 bit Which Enpass version are you running: Enpass 5.6.0 Which cloud sync are you using: Google drive Are you using browser Extension: Yes What action did you performed, after which app started hanging: described above; this last time I was making a postman call to some endpoint and realised I needed a password from enpass (which was opened before, but not logged in) Edited October 9, 20179 yr by Andrei
