September 17, 20206 yr Hello, I'm trying to setup enpass on a new iPhone SE with iOS 14. When I install enpass, sync my cloud data and so on, everything is ok. First I'm getting only 10 items, then I try to unlock Enpass as an allready registered user .... usually thats no problem, I've done this often. I get the OTP Code by Email, enter the code in the app, but then I'm getting an "Unknown Error" ... is this a Problem with iOS 14? Edited September 17, 20206 yr by To Kö
September 18, 20206 yr Hi @To Kö, This could be a temporary glitch. Please make sure that you are connected to the internet while submitting the OTP. If the issue resurfaces, please share the Enpass version and the device model. Thanks.
September 21, 20206 yr Author Hello, there was an update of the ios app available on the weekend. It did work now! Thank you!
