September 21, 20206 yr Hello, I have imported from Dashlane following the quote published, everything seemed ok however the Domain for all the logins the field type has imported as ‘text’ and not ‘url’ this means that all logins are not showing when visiting the sites. Can I bulk change all these without going manually through them all? Thanks
September 24, 20206 yr Hey @Walkerj Welcome to the forum! Thanks for reporting this issue. We have found the problem and are now planning for the fix for it. Thanks!
October 13, 20206 yr On 9/24/2020 at 12:10 PM, Garima Singh said: Hey @Walkerj Welcome to the forum! Thanks for reporting this issue. We have found the problem and are now planning for the fix for it. Thanks! Any updates? Is it fixed?
October 13, 20206 yr Hi @Avi, Thanks for writing back in. Our Dev team is working on it. Hopefully, fix will be available in the future updates. Till then, we will request you to please co-operate with us.
