September 23, 20206 yr Can not work finding/searching "password" field items. For instance, data item as "aBc123" in "password" field item. Then try search "aBc123", the result was "0". If changing from "password" to "text", it hit the result "1". I can find the item. So, how can I find/search "password" field item? Edited September 23, 20206 yr by Kaz
September 23, 20206 yr Hey @Kaz Welcome to the forum! You can search for any data saved inside the Enpass app. To do so, please change the search preference option from ‘Title/Fields’ to 'passwords'. Let me know if the problem persists. Please go through this link to our user manual to know more. Thanks!
