September 23, 20206 yr In the Enpass browser extension for Chrome, I have the option "Autofill details without showing Enpass assistant" enabled. I assume this means when I visit a login page, Enpass should automatically enter my login details, without having to manually click the toolbar icon and select the site. However, this rarely works. Even when the URL matches exactly and there's only a single entry for the domain, I almost always have to manually fill the login form by clicking the extension icon or right-clicking and selecting Enpass from the context menu. I'm using Enpass version 6.5.707.
September 24, 20206 yr Hey @Brad Konia Sorry for the inconvenience. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass extension version are you using? Let us know the websites in which you are facing this issue? Are you facing the same response with other browsers too? Also, let us know, which part of Auto-fill is not working. Whether username/password fields are not getting filled or it is not getting auto submitted after filing the login fields? Thanks!
