September 28, 20206 yr use equipment: iPhone 11 system: iOS 14 Web environment:United States and Hong Kong Fault description:On my iPhone, open enpass and select Dropbox for data synchronization. You can connect to Dropbox, log in successfully, authorization is successful, But data cannot be synchronized. other:When using a computer, my enpass is normal. I can connect to Dropbox for data synchronization. So far, this only happens on the iPhone. At last:I hope the next update can solve this problem, and I wish you all the best in your work!
