September 28, 20206 yr Hello, I have been using Enpass for 18 months without any problem. This afternoon, the Enpass extension of Firefox refuses to recognize my main password to unlock the software (I typed the psw for verification in Word: no problem with the keyboard). I'm starting to get scared because the Desktop application also refuses it and after restarting the PC offers me a new different screen as if I were a new user. Fortunately, as an already known user, I was able to start again from an automatic backup that dates back 3 days. It does not matter, I have recovered access with my main password and my data. But what happened? Temporary bug, hacking .... do I have to change my passwords (the main one of EnPass, all the others?). After several connections attempts, is it normal for EnPass to ask you to restart from an automatic backup from the PC Backup folder? For your information, the only process not usual today was to install and execute Malwarebytes 4.2.1.89 on my PC Thank you for your reply Edited September 28, 20206 yr by Vital
September 29, 20206 yr Hi @Vital, Sorry for the inconvenience caused to you. This seems to be a strange behavior. We would need some inputs from you to further investigate this issue: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Are you trying to Backup on any Server/Network? Have you changed the Default database location of Enpass? Are you using Enpass on any other devices? if yes, are you facing this issue on those devices too? Also, please share the OS version and Enpass version. Thanks for your co-operation.
October 1, 20206 yr Author On 9/29/2020 at 10:17 AM, Pratyush Sharma said: Hi @Vital, Sorry for the inconvenience caused to you. This seems to be a strange behavior. We would need some inputs from you to further investigate this issue: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Are you trying to Backup on any Server/Network? Have you changed the Default database location of Enpass? Are you using Enpass on any other devices? if yes, are you facing this issue on those devices too? Also, please share the OS version and Enpass version. Thanks for your co-operation. Hello, I am using EnPass 6.5.0 (707) on a PC with Windows 10 I configured my backup with dropbox but I restored my configuration and my database with a version saved on the PC 3 days ago (a manual backup I presume) I did not change anything in the default Enpass database location before the problem I also have EnPass on another PC but it was not in use when the problem occurred. I haven't tried using it to see if I was stuck as well. This laptop PC is also equipped with the W10. Thank you for your attention
October 5, 20206 yr Hey @Vital Thanks for your reply. We assume that it has something to do with the Malwarebytes installation on the system. Did you ever face the same problem before?
October 7, 20206 yr Author Hello, Thanks for your inquiry. I have never had this problem before. I only downloaded and installed Malwarebytes a few hours before the problem connecting to my account on EnPass Today everything is OK after the restoration of the Epass database. As long as it lasts! Thank you
October 8, 20206 yr Hey @Vital Thanks for notifying us. Glad to know that this is resolved, you can revert us back if the same problem resurfaces again.
