September 29, 20206 yr Over the last little while (and unfortunately I did not note if it was subsequent to a version update) Enpass is freezing on my mac. Most commonly the save button does not appear to function at all. However even though the save button is in a PERMANENTLY GREYED OUT state - sometimes items save and sometimes they do not. However Enpass is seriously messed up.
September 29, 20206 yr Author BTW - neither the save or the cancel buttons or the + button do anything
September 30, 20206 yr Hi @Toronto, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Which cloud sync are you using to sync data? Are you facing this problem in any specific case or just while adding the items and clicking on the save button? Thanks for your co-operation.
October 1, 20206 yr Author macOS 10.15.7 sync via iCloud enpass v 6.5.0 (700) all menu buttons on the app are permanently greyed out Does enpass have a local memory limit - what's going on? to add a new entry I now have to use my iphone and sync/can't add a new entry on my mac. I can view all items on the mac but can't add them - the entire menu bar - including the search, cancel and save button are greyed out - the entire app is useless on my mac now. I can use the search if I don't attempt to enter any new data first so it is still minimally functional to look up entries. I have 917 entries .. and now I'm concerned I've trusted all that data with an unstable app.
October 1, 20206 yr Author Oh - the sync button doesn't work either - I can do start it from the top level menu though
October 1, 20206 yr Author Just noticed - the show tab bar and show all tabs is greyed out in the top level menu
October 1, 20206 yr Author the menu is so messed up that if I open the about menu I can't close that window because clicking on the x does nothing - I have to exit the app. you've really managed to break this app - was it the last "update"?
October 2, 20206 yr Author I've never had any issue with Enpass (other than an iCloud syncing issue on a new account setup). This must be related to the recent version update - is it?
October 5, 20206 yr Author I'm sure I'm not the only one with this issue. I'll like to assist in any manner possible to resolve it. Please indicate what your path forward is re a fix.
October 5, 20206 yr Author Hello?? I can't create a new entry on my mac in Enpass. Maybe an issue that serious is worth a reply?!?! I'll give it until tomo ... then I'm exporting out to something reliable -- this is BS.
October 6, 20206 yr Author I figured out a (very inconvenient) workaround ... and now have the info that can isolate the issue for you ... but ... as you went radio silent although you advertise "premium support" ... don't ask me ...
October 6, 20206 yr Hey @Toronto We regret the inconvenience, but we're here for help. We did not come across such an issue while looking for the problem at our end. Is it possible for you to share a snapshot or a screen-record when the problem surfaces? Thanks.
October 8, 20206 yr Author Hi: Ok ... for the benefit of the countless other Enpass users that likely can't use the app right now ... I will assist. As I mentioned ... none of the buttons in the main app window work. You can click on them ... but nothing happens. The top menu works ... but unfortunately you have not included a save function there (you should change that). As such no new items can be added and no existing items can be edited. The app can only be used to look up existing entries. This problem is new. I have been an Enpass user for years and have never experienced anything like this. Here's something I discovered accidentally ... and that will direct you to the problem solution. I by chance clicked on the green button in the app window and maximized the window - not something that represents a preferred window size when working with a password manager. Nonetheless, when the app window is fully maximized, the buttons work and I can use the app. If I click on the green button again and reduce the window size to "normal" the buttons cease to function. I'm confident you currently have thousands of users that require a fix asap.
October 30, 20206 yr Author So a month later ... and you still find it acceptable that now the only manner in which users with high res displays can use Enpass is by fully maximizing the application window ... as any smaller app window size and the search bar won't accept text and all the buttons no longer function - you've pushed a lot of updates in the last month - when are you going to fix this?????
