October 12, 20206 yr Hello together! I have changed from "Keepass" to "Enpass". Enpass works very well for websites. But with software passwords there seem to be problems. I use "Starmoney". When starting the software I have to enter a password (only one password). With Keepass this was no problem, but with Enpass it doesn't work. Is it also possible in Enpass - and if so, how? Thanks!
October 13, 20206 yr Hi @Michail, Enpass does not auto-fill login info on desktop apps. It does however auto-fill on mobile apps. If you are facing problem on the mobile version of Enpass, please share the following details so that we can investigate where the problem could be:- On which device (along with OS version) are you using Enpass? Which Enpass version are you using?
October 13, 20206 yr Author 10 hours ago, Pratyush Sharma said: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks @Pratyush Sharma! I use Windows 10 Pro (1909). I use Enpass 6.5.0 (700) on the desktop + browser plugins.
October 14, 20206 yr Hi @Michail, Thanks for sharing the details. Please share the details of the website on which you are facing this issue to investigate it further.
October 14, 20206 yr Author 4 hours ago, Pratyush Sharma said: Please share the details of the website on which you are facing this issue to investigate it further. Thanks @Pratyush Sharma What kind of website?! StarMoney is not a website, but a desktop software. Please read my OP again!
