October 15, 20206 yr Hi All, I have enpass installed on my work computer and it is detecting a program called EnpassBridge.exe that is been classed as Malware with a 73/100 threat score. Can you any shed any light on this?
October 15, 20206 yr Hi @finswim01, Thanks for writing in. That's strange! Please let us know where did you get the file from? We strongly recommend our users to install Enpass only from the stores or our official website. The reason is that applications on store (and of course website) are signed with developer certificates, and delivery through it assures that the software is genuine and not tampered with. On the other end, installing Enpass from third-party websites might put you at security risks.
October 15, 20206 yr Author Hi Pratyush, I can confirm that Enpass and Enpass extension were only installed from MS windows store. Thus it would suggest that Enpassbridge is part of the official installation software.
October 15, 20206 yr Author Additional, these files are installed in the windows app directory (windows hidden directory) that i don't have edit access to (admins only) which also says it's part of the official windows store installation.
October 16, 20206 yr Hi @finswim01, Thanks for writing back in. Please let us know which Antivirus and its version are you using so we can further investigate.
October 19, 20206 yr Hey @finswim01 The component EnpassBridge.exe has been added recently in 6.5 version. This is a False Positive probably based on low install-base score. We have submitted a false positive report to mime-cast team. Thanks!
