October 15, 20206 yr I use Enpass on several devices and synchronise with Dropbox. I want to change this in synchronising with Icloud. Cannot find how to do this
October 16, 20206 yr Hi @Michael G., Welcome to the forums! We will suggest you disconnect sync from all the devices and then connect it again with the iCloud. To enable, please follow the below steps- Open Enpass → Settings → Tap on ‘Vault’ → ‘Disconnect sync’ under the Setup sync → 'Setup sync’ again --> Select the iCloud and enter your cloud account details, follow the instructions and wait till the sync is done. Now open Enpass on all other devices and enable sync with the same iCloud you configured in Step 1. Hope this helps!
October 16, 20206 yr Author Thanks, works fine, avoids me to have to pay for dropbox as I went over the maximum number of equipment connected to dropbox.
