October 23, 20206 yr Syncing to Nextcloud via webdav stopped working a while ago for me. Started to look at it now and I tried to disconnect sync from the client and setup sync from the beginning again. I also renamed the Enpass folder in Nextcloud so that a new one would be created. Setting up sync works fine but when it's supposed to sync it just gives me an error: Something went wrong while syncing with Webdav. Error code: 0 If I check my logs the client seems to be getting a 401 unauthroized respons: xxx:1.2.3.4 - - [23/Oct/2020:21:54:13 +0200] "PROPFIND /remote.php/dav/files/xxxx/ HTTP/1.1" 401 557 "-" "Mozilla/5.0" And if I strace the processes while I try to sync I see this: <s:exception>Sabre\\DAV\\Exception\\NotAuthenticated</s:exception>\n <s:message>No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured</s:message>\n</d:error>\n" So Enpass is not sending any authorization information?
October 26, 20206 yr Hi @agent92, Sorry for the trouble you are going through. Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Did you start facing this issue recently - like after an Enpass update or did you face the same problem earlier as well? Did you make any changes to your WebDAV account recently? Is it possible for you to share a demo account of your WebDAV server on support@enpass.io, so we can set up the sync at our end and check for issues?
December 27, 20214 yr Hi, were you able to solve this issue? I'm getting the same error with Nextcloud. On which devices and OS versions (mention all) are you using Enpass? --> all (IOS / windows) Which Enpass version are you using on each device? (6.7.4) Thanks, Ruben
