October 26, 20206 yr I've enjoyed using Enpass for a couple of years now, purchased a license too. However, as of late my Enpass window keeps "Not Responding" when I try to use it. I've uninstalled it, removed all registry entries and reinstalled it. This has not solved the issue. I've been installing it from the Windows Store. I've downloaded the manual install as well directly from the Enpass website, but it's doing the same thing. When I use it on my Android phone or my Surface Go (Windows Store version) I have absolutely no issues and it works fantastically. My database is 1.25mb and resides in OneDrive.
October 26, 20206 yr Hi @S31FER, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which OS version are you using Enpass? Which Enpass version are you using? Number of items and Vaults in Enpass? Let us know if any particular scenario or step causes unexpected behavior.
October 26, 20206 yr Author Hi Pratyush, I'm running Windows 10 Home (64 bit). Version 20H2. I'm using the latest Enpass from the Enpass website and previously, the Windows Store. Not sure about how many items, but roughly 150. Only one vault. As for any scenario, there is none besides opening the application.
October 27, 20206 yr Hi @S31FER, Thanks for sharing the details. We have taken note of this and our team is now analyzing into the issue.
October 28, 20206 yr Author So I'm SOL if I want to use Enpass on my main PC. It worked fine a couple of weeks ago. Since then though, I've had a couple of Windows updates. Edited October 28, 20206 yr by S31FER
November 2, 20206 yr Hey @S31FER Thanks for writing in. Please share the HDD/SDD setup of your Windows device or if you can see disk activity in Windows Task Manager at 100% while this Enpass issue persists. Also. share the exact version where this issue started happening and at which point/scenario, app is getting hanged and how frequently? If possible, you can share a video of the same, that would be beneficial to diagnose the issue.
November 19, 20205 yr I'm having the same exact problem on both of my computers (a surface pro 5 work computer and surface pro 7 home computer). The Pro 5 runs Windows 10 version 20H2, the Pro 7 has not yet upgraded to 20H2. My cell phone app (Samsung) works fine. I'm running App version 6.5.1 (or whatever the latest windows store app version is) and have 121 items in my vault (which is stored in OneDrive). I've tried terminating the app, repairing the app, and removing and reinstalling the app.
November 20, 20205 yr Hey @dmedich Welcome to the forum and thanks for sharing these inputs. The details has been shared with the team to look into this issue. Please co-operate with us.
February 22, 20215 yr Hey @S31FER & @dmedich Thanks for the patience. Please upgrade Enpass to latest v6.6 as we've improved few things there that which might help. If this doesn't work, please share your HDD/SDD setup or if you can see disk activity in Windows Task Manager at 100% while this Enpass issue persists.
March 30, 20215 yr Hi, i've the same problem but on Ubuntu 20.10 with Enpass 6.6.0 (775) (Pro Lizence). Permanently had to restart the Enpass app because it crashes or didn't respond.
March 31, 20215 yr Hi @Huaba, Sorry for the inconvenience caused to you. Please update the Enpass app to its latest version(6.6.1) and let us know if this still persists. Thanks!
