October 27, 20206 yr Username and password autofill is great, but it breaks on sites (such as for certain security appliances) where the password and OTP have to be entered into the same field. Obviously the work around for this is to not use autofill, but it's only an issue in this particular case. Some options for an improvement might be: A per-entry whitelist that works like a boolean of "copy both password and otp for this site" consisting of the password and otp concatenated together in the clipboard, with option of Password+OTP or OTP+Password, for some schemes where the OTP is required before or after the password proper, A right-click option under "Copy OTP" that allows for "Copy Password+OTP" and/or "Copy OTP+Password", for some schemes where the OTP is required before or after the password proper, or Both of these. I hadn't seen such an option in the desktop client for this, so either I missed it, or it's not there. Either way, great application!
October 28, 20206 yr Hi @NateTheSage, Welcome to the forums! Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Also, let us know on which website you are facing this issue?
November 3, 20206 yr Author It's not so much a problem as it is an inconvenience, but sure! Pretty much any client is affected. I'm using the latest version for Windows, Android, and Linux. The site it's an issue on is my OPNsense login page, to name one. On that page, autocomplete tries to fill in the password, which invariably fails because the password prompt is expecting password+otp. It's kind of a really isolated issue, but I figured a feature request for something like this would be nice as a lot of security appliances that bolt-on OTP do it like this. Thanks!
November 4, 20206 yr Hey @NateTheSage Thanks for writing back. Please have a look at this link to our user manual to know about TOTP feature available in Enpass. Let me know if this doesn't help you. Thanks!
November 4, 20206 yr Author I know, I'm already aware of this feature and use it regularly. What I'm asking for is an option not unlike "Copy Password" and "Copy OTP" that lets me concatenate both the password and OTP into a "Copy Password+OTP" option. Let me be perfectly clear I'm not asking for support, I'm making a feature request, the OTP functionality of Enpass was half the reason I switched.
November 5, 20206 yr Hey @NateTheSage Thanks for using Enpass and sharing this. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted for further consideration. Thanks for the suggestion!
December 22, 2025Dec 22 Hello, My family, friends, colleagues, and I have been using Enpass for a long time now and are satisfied with the basic features—however, there is a lack of new features that keep up with the times. I have been following this and other topics (e.g., Yubikey integration) here in the forum for a long time. Unfortunately, nothing much is happening with the feature requests. This is becoming frustrating. Of course, I understand that development costs must be justified - i.e., enough users must want/use a feature for the expense to be justified. I also understand that features are not integrated if it is not worthwhile – but I would then like to see open communication – i.e., Enpass clearly stating that this or that feature will not be integrated/developed. So I'll ask again, tentatively: Will this feature, or Yubikey integration, or other features that users have been waiting for for a long time, be coming? And if so, is there a rough timeline - for example, in 2026? Thank you Best regards, xDA
January 12Jan 12 This feature request is shared with our technical team. However, it's pending for prioritization, and we sure would look to add this in our roadmap in the near future. We thank you for your patience and understanding! SI-1203
March 6Mar 6 On 1/12/2026 at 2:09 PM, Tarun Singh Rawat said:This feature request is shared with our technical team. However, it's pending for prioritization, and we sure would look to add this in our roadmap in the near future. We thank you for your patience and understanding!SI-1203Is this ever coming to EnPass? Would be great really to have this as an option to use on a platform like OPNSense. Thanks for your efforts.
