November 1, 20206 yr Hi, is it possible to sync the data into multiple cloud storages simultaneously? Like to have 2ndary backup place.
November 2, 20206 yr Hey @tajred Welcome to the forum! Thanks for using Enpass and writing to us. Currently, you can sync Enpass data using multiple cloud accounts on the same cloud. However, syncing data using one cloud account with multiple vaults feature is still not possible in Enpass. For more details, refer to this link. Thanks!
December 24, 20205 yr Author Hi @Garima Singh, So how can I perform secondary backup from my main cloud provider? Let's say my main cloud sync storage is compromised or not available. So I would like to switch to different backup cloud storage. Is that possible? Thanks.
December 28, 20205 yr Hey @tajred Thanks for writing back. You can do so by disconnecting the sync of the particular vault, while disconnecting the sync, make sure to enable the option 'Also delete data from cloud' and then click on continue. Now you can setup sync again with any other cloud. Let me know if you have any concerns. Thanks!
