System try icon under gnome 3.26 and above
Gnome in version 3.26 removes legacy system try. From this time the system try icon of enpass isn't visible in any way. If I use topicons plus extension or appindicator extension to gnome shell it isn't visible too.
Edited by dw72
  • 1 month later...
That's true. I also encounter this problem since updating to Fedora 27 (Gnome 3.26.2) today :(
Other legacy icons (like cloudstation) still works with Topicons Plus gnome extension.
Edited by nech+arHU
  • 5 weeks later...
Hey enpass stuff, do you think about solving this problem or do you treat it if it was not?
Hey guys,
Sorry for the trouble you are going through. To investigate further on this issue, we will be needing your system information. Please run the command $screenfetch in the terminal and share the output with us. And yeah, before running the command make sure you have screenfetch installed on your system.
Thanks for your co-operation.
6 hours ago, Anshu kumar said:
Hey guys,
for me it is:
 OS: Fedora 27 TwentySeven
 Kernel: x86_64 Linux 4.14.16-300.fc27.x86_64
 Uptime: 10m
 Packages: 2144
 Shell: bash 4.4.12
 Resolution: 3840x1080
 DE: GNOME
 WM: GNOME Shell
 WM Theme:
 GTK Theme: Adwaita [GTK2/3]
 Icon Theme: Flat Remix
 Font: Cantarell 11
 CPU: Intel Core i7-4870HQ @ 8x 3.7GHz [63.0°C]
 GPU: AMD HAWAII (DRM 2.50.0 / 4.14.16-300.fc27.x86_64, LLVM 5.0.0)
 RAM: 2678MiB / 15992MiB
$ gnome-shell --version
GNOME Shell 3.26.2
