Importing Data Does not Get Icons
I just started using Enpass but one thing that does not seem to work is automatic icons. I imported my previous passwords but they do not have icons associated with them. New accounts, however, do automatically get the icons. Is there a way to get all the icons without doing it all manually?
Hi @ProJedi,
Unfortunately, it sets the default Login icon for all imported items. I know this sounds a bit wonky, but we will definitely improve our import function in future versions.
  • 3 months later...
I just bought the app and really think that the feature would , I'm sure , be appreciated by a great number of users. You state that you will definitely improve your import function in future versions, can you tell us when you think t'll be ready.
Hi @Chris1003
Thanks for writing in. In version 5.3.0, we have improved the import process, in which icons are imported from the URL of the items. So please check and let me know does it works?
Cheers!
Hello Anshu,
Sorry to disappoint you, I am on 5.3.1 (60) and it does not work. Is there a particular setting or procedure to apply , thanks.
Hi Anshu,
I am so confuse, it works now !
Thank yod very much for your concern.
Take Care
