November 29, 20206 yr I'd like to see the Category & Template used for an entry. Possibly where the Last Modified and Created dates are. Not modified by user, changes if moved to new Category.
December 3, 20205 yr Hey @macRBC I was able to find other forum post you created and reverted you on the same. To prevent duplication of efforts, please revert on the same if you have any concerns. Thanks.
December 23, 20205 yr Author I'm confused which thread to use but still wanted reply to how to apply new template to existing records.
December 24, 20205 yr Hi @macRBC, Thanks for writing in. On 11/29/2020 at 10:11 AM, macRBC said: I'd like to see the Category & Template used for an entry. Possibly where the Last Modified and Created dates are. Not modified by user, changes if moved to new Category. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
