Dropbox-Sync failed
After Update to MacOS 11.2 the dropbox-sync doesn't work. I have disconnect the sync and tried to connect again then everytime the message: "Could not verify your credintials. Please log in again to sync your data."
Restart, dropbox-logout, nothing helped.
Hey @StoST,
Apologies for the inconvenience.
Today, we've released an update with a fix to this issue on all the platforms. Please update the app and let us know if the issue still persists.
Thanks.
I am still experiencing this issue on the Mac OS app. @Pratyush What is the process for updating to the latest version?
Edited by nwilson126
edit
SAME ISSUE HERE
On desktop (MACOSX) can you update via the app? I don't see anything under prefs
Please detail how to update? Im a pro user. thanks
App Store just spins forever.  Enpass needs a proprietary update option in Preferences.  Relying on the App Store is like expecting police to show up in time to save you during a home invasion.
Edited by Texconsin
Hi @aaronbernak @Texconsin,
Apologies for the trouble you are going through.
It might be some technical issues with the App Store. Could you please retry after restarting the system? If the problem persists, please let me know in which country you are facing this issue so that we can investigate it further—also, the OS version of your device.
Thanks.
