January 23, 20188 yr At this point in time, between Enpass jumping into other tabs, jumping into the "Tabs you have set aside", the desktop application crashing almost every time I use Enpass and the extension connection error, Enpass it is pretty much unusable, I have so many issues every time I try to use it
May 8, 20188 yr I have the same issues and it's getting really annoying. Especially the Enpass client crashing and the Edge extension making your cursor jump around.
May 30, 20188 yr Hey guys, Sorry for the trouble you are going through. We've been looking into this issue and found that the crashes were prominent when using Enpass with " Windows 10 x64 1803 (17134.81)". So please update the latest preview OS build(17677) or either use a stable version of OS and let me know if the problem persists. Cheers!
May 30, 20188 yr Windows 10 x64 1803 (17134.81) is the latest stable build for 64-bit Windows 10 that Windows Update is having users update to. Please help.
