February 27, 20215 yr Export in csv and txt format is suddenly not allowed. The only option is json format. I was previously able to export via csv and txt format. Does anyone know why? I'm running the desktop version 6.6 of enpass.
March 1, 20215 yr Hi @JJK, Sorry for the inconvenience caused to you. That's strange as we haven't made any changes in export. When you say it's not allowed, what error message are you getting? Also, please make sure the destination path has required permission to save the file. If it still doesn't work, let us know the following details so we can help you better: On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks for your co-operation.
