WebDav sync failure after Synology WebDav update
After Synology pushed a Webdav update to their NAS systems none of my devices are able to sync.  All devices say "No data found on WebDAV".  On my PC I disconnected and attempted to reconnect and get the error that it could not connect to the specified folder - check password and username.  I used the exact same settings to log back in.  This connection problem appears on Windows, Android, and iOS.
Thank you for any help you can offer!
Hey @BCMguy
We regret the problem you are facing, but we’re here to help. To proceed with the troubleshooting, please share a demo account of your WebDAV server over PM or via mail at support@enpass.io, so we can set up the sync at our end and check for issue.
I experienced the same,  here is my fix;
htpps://my.synology.me:5006
