February 6, 20188 yr Changing the Data Location isn't working the way I want. I want the walletx.db to be stored in the location "e:\Software\Enpass\Data". But the Settings menu keeps appending the "Enpass" folder to the end of the location I want. I also had a similar problem with the Backup location, but was able to change this via enpass.conf file. Enpass Windows Desktop v5.6.5 Edited February 6, 20188 yr by jakejohn
February 7, 20188 yr Hi @jakejohn, 12 hours ago, jakejohn said: I want the walletx.db to be stored in the location "e:\Software\Enpass\Data". But the Settings menu keeps appending the "Enpass" folder to the end of the location I want. Actually, it's a default behavior of the app and it creates its own folder if it doesn't find the Enpass folder in that location.
