Saving Webform does not seem to work (option does not exist in menu)
I'm on Windows 8.1 x64, using the latest Chrome 89, but I also tried Brave 1.22. I've followed the instructions here: https://www.enpass.io/docs/manual-desktop/browser_ext_using.html#saving-webforms
I filled in the form, then I brought up the assistant in the browser (right click > Enpass) then I clicked on the hamburger menu, but there is no entry "Save Webform". All I see is the screenshot below. Otherwise Enpass works fine. Any ideas?
Also, why can't we manually add a webform for an Enpass entry?
Edited by johnq
Hey @johnq
Thanks for sharing the details.
Currently, Enpass only gives the save Web-form option if there are username and password field in the Web-form page. If both fields are available and still you are not getting the option to save Web-form, then please let us know on which website you are facing this issue along with the Enpass version you using on the same device.
