April 17, 20215 yr Hi, after reformatting my system, I can't install enpass via the Microsoft store anymore. Installation fails with "Code: 0x80073D05". Store installation worked on the same system before as well as on other devices. Microsoft Windows 10 Pro Version 10.0.19042 Build 19042 Portable version works fine, though. Any hints? Thanks Edited April 17, 20215 yr by jnkthms
April 19, 20215 yr Hi @jnkthms We are sorry for the inconvenience caused to you. The error occurs when the operating system cannot install the application for an unknown reason. Sometimes the problem gets resolved by restarting the computer and trying to install the desired program/app again. Please go through this link for troubleshooting and let us know if it is useful to you. Thanks!
