May 2, 20215 yr After deleting some webforms, the labels are still in the database. They can be seen in the exported files and will be found by the search field too. They are *not* displayed when the entry is edited. How can the 'zombie' data get deleted ? When will this bug get fixed ? Regards.
May 3, 20214 yr Hi @HB1, Thanks for notifying. We've been able to reproduce this issue and will work to fix it.
