May 26, 20215 yr I cannot find the option to hide the passwords in Enpass on BigSur. The passwords are always visible I can choose in edit mode though, but default is visible there as well. Does anyone knows where this option is? Regards!
May 26, 20215 yr Hey @RicardoD Welcome to the forum! To hide the passwords within Enpass, you can follow the method: Open Enpass > Settings > Security > Enable Hide Sensitive. This option is set enabled by default. Also, you can also set the non-password field of a particular item to be sensitive by enabling the box given below the field type. Attaching an image for your reference:
