backup and how to restore
I am a new user on enpass.   I have installed it on my apple phone.   What happens if I lose my phone?  I saved a backup on my desktop.  At least I think I did.   It is an encrypted download I think.   How will that help me if I lose my phone?
Hey @KFM
Welcome to the forum!
Yes, your backup is encrypted with your master password. Then can restore your backup with:
  1. Restore using WiFi: If you have Enpass backup on the desktop, you can restore the data using WiFi restore option from the desktop to mobile device.
  2. Restore from cloud: If you have  synced Enpass data with any cloud on your iPhone, using which you can restore the Enpass data on a new device easily.
Thanks!
  • 1 month later...
hello!
i cannot find the restore option on ios mobile nor desktop version... i have only backup option on both devices...
any idea?
thanks a lot!
Hi @Mihai,
On the welcome screen of the freshly installed Enpass app on iOS, you will find it under option Restore Existing User. Then you can either restore data from a Cloud Account or from a Backup file ( or over Wifi). You will find these options in Desktop app welcome screen too.
               461450196_MicrosoftTeams-image(1).png.fc7d53716b933f1b499463b749f69324.png                                               MicrosoftTeams-image.png.91fa3924bfbd46e3c57d271794ef52ef.png
